Banjo bolt too long
Discussion in 'General 1000RR Discussion' started by Slick, Dec 21, 2013.
  1. Slick
    Slick Elite Member
    My banjo bolt has arrived today (after nearly 2 week in the christmas post!).
    Dry fitted into my new RCS master and it's only too fecking long:mad:
    My question is it safe to make up the gap by fitting extra crush washers?
    It's a titanium one so would rather use it if I can.
  2. ColinBR
    To be honest mate even with washers it's just going to look out of place.
  3. ColinBR
    Can you post a pic of the banjo bolt as I think you may be able to chop it down if you have the tools
  4. Slick
    Slick Elite Member
    right you are! I guess there's no point taking shortcuts on something relatively cheap.
  5. Jase
    Jase Elite Member
  6. Slick
    Slick Elite Member
  7. scooby
    scooby Elite Member
    how much gap is there with the lines in?
    i'll double up on copper washers if needed,but wouldn't go any more.
  8. Skippy79
    Skippy79 Active Member
  9. ShinySideUp
    ShinySideUp Elite Member
    You could possibly cut the banjo bolt down and redress the end of the threads but like mentioned you really need the right tools to do it properly so you don't strip the threads on the MC.
    I also wouldn't recommend using multiple crush washers either as they will most likely have a tendency to leak from between the washers, seen it happen many times on oil sumps where people don't remove the old crush washer n fling a new one on with it causing an oil drip leak.
    Have you tried contacting the company you got the ti banjo bolt from and see if they supply smaller bolt lengths? Might be the simplest way forward.
  10. Slick
    Slick Elite Member
  11. Slick
    Slick Elite Member
    no special tools I'm afraid
  12. Slick
    Slick Elite Member
    Thanks both, It's more impatience on my part,- I've been waiting to fit for nearly two weeks(bolts was lost in the post)! with the Xmas period I might have to wait till Jan for replacement. The RCS comes with a double banjo bolt but you're right should have got it direct from the supplier instead of going bling on a titanium one.
  13. scooby
    scooby Elite Member
    yea 6 washers is too many.
  14. Elric
    Elric New Member
    I cut bolts to the correct length all the time. If I was doing that one then I'd put it in a vice then cut with a hacksaw and dress the cut thread with a small file and because the end of it is dished you might have to redo the dish with a drill, I don't see a problem with cutting it.
    #15 Elric, Dec 21, 2013
  15. ColinBR
    If you know of anyone with a small lathe then you can get them to turn it down to size for you no probs.
    I'm not sure how far our Arthur is from you, but if you speak nicely to him, he may be able to help you.
  16. Jase
    Jase Elite Member
    I think for the sake of a £5 I would just order the correct bolt .:D
  17. kev.b
    kev.b Well-Known Member
    As Jason said buy a correct bolt . I had to add 1 extra copper washer when I fitted my Galespeed mastercylinder , I would not advice adding more than 1 extra or cutting the banjo . You could phone Venhill they will be able to help .
  18. wedgiewolves#223
    wedgiewolves#223 God Like
    Do y know if this has been mentioned but I always use these when the bolts are too long
    http://bit.ly/1jtO5qh
  19. derchef
    derchef Well-Known Member
    unluckily brembo need short (special for)banjo
