Hello folks just wondering if anybody on this has had the problem I am having,I have just changed the battery and stator on the bike but the battery is still not keeping a charge can anyone help cheers
Is it that your bike isn't charging the battery when you run it, or is it draining the bike when stood? If it's not charging then you should be able to check the running voltage, should be over 13 volts. If it's draining when stood then stick an amp meter in line with the battery to see what the drain is and then disconnecting thinks, starting with the alarm.
1st disconnect the battery earth strap over night to be sure the battery is ok. Next I would disconnect the reg/rec overnight, a knackered diode will discharge the battery.
HM QS Plus SH, Rizoma Brake Fluid Tanks /LED Indicators/bar ends, ASV Levers, Heated Grips, Honda Sport Pack, R&G Parts, Alu Chain Guard, Speedo HealerV4, Garmin Montana, CNC Foot pegs etc., Repsol Hugger on ABS Bike, Acumen DG-8, R & G Tail Tidy, Datatool 4, Datatag, Gel Seat, LSL Oil Filer Cap, PCV Custom map, K & N Filter, Sequential LED Tail Light, Carbon Fiber Heat Shield, Solid Lubrication Sys , Samco Hoses, Accassato Quick Action Throttle Kit, Gilles Chain Adj
I would start with the datatool's they always cause problems. disconnect the neg lead then put a meter between the lead and the battery and see what is drawn out. with the ignition off the leakage should be 2mA leakage, any more than that will be alarms etc.
