Battery
Discussion in 'Maintenance' started by Bladelat_08, Jun 4, 2016.
  1. Bladelat_08
    Bladelat_08 New Member
    What a good battery or race battery for my rr9 with hrc subframe with battery box? Just want to have as back up to the one that's fitted to the bike!
  2. Mr OCD
    Mr OCD Well-Known Member
    Shorai Lithium :)
  3. RRoss
    RRoss Active Member
    Shido lithium and more affordable.
  4. bonjo
    bonjo Active Member
    -1 as a back up and for race application, lithium is good and save you a little weight.
    But for general all year around road use including cold weather starting, I personally go for led acid
  5. callumw
    callumw Active Member
    As a backup you can get a compact battery pack for about £30 that you can use as a jumpstarter, but if you've started using that then your battery may be at its end of days. Mine was struggling to hold charge in winter, so instead of getting the jumpstarter or a new lead battery, I put the money towards a Lithium battery instead.
    SHIDO LTZ7S LION -S - was about £64 on Amazon
    To compare, the stock Yuasa YTZ7s replacement is about £50
    When swapping I weighed them (nerd moment)
    The Yuasa factory battery was 2.08 Kg.
    The SHIDO replacement was 540 g
    For cold starts I switch the ignition on and then put my gloves on before starting the bike.
    In theory having the lights on for that 30-60s pushes current through the battery, warms it up and so it gives more power.
    Never had a problem starting it from as cold as -5C and I'll leave it up to a month with no top up charging on it.
