Plz forgive me as I've looked on the forum for the sizes but can't find them. Does anyone know the wheel bearing sizes for the 929 (2000 - 2001/2)954 (2003) off hand Regards Tim
Front wheel 2 X 6005 ------ID=25mm==== OD=30mm------ depth 9mm Rear wheel 1 x 6005 ------ 1 x 6205 Sprocket carrier I believe is a special 6028 you need to research this as there are some variants
Many thanks for the info . I've made a note of this now. I looked on line last night but it just came up with the OEM part number and not the bearing size. I have at some point replaced all the bearings in both wheels with the Exception of the spricket carrier. I've tried the local bearing Supplier to no avail. Gone online and if my memory serves me correct its rather Expensive. Regards Tim
Currently I'm dealing with another member on the same topic. The sprocket carrier 0n the 04-07 carries a double 6028 bearing which is a special and retails at around £50ish. These wheels are identical just lighter. cheers Mique
I have a Dvd full of motor bike manuals of many makes, i just looked at the 954 one - But the hub bearing only shows as ( 27 x 52 x 23.8 ) WHY is nothing Simple lol
