Best front stand ?
Discussion in 'General 1000RR Discussion' started by Hudson, Oct 30, 2012.
  1. Hudson
    Hudson Active Member
    Looking to match a front paddock stand to my Abba Stand, not sure which is the best one and which method to use, ie the ones that lift with those prong things or the other one that lifts either side of the fork leg.... any recommendations.
  2. viper_biker
    viper_biker Active Member
    With an ABBA stand, I'd recommend an under yoke stand. Every bit as easy to use as the ones that lift from the fork legs, but lets you turn the steering, swap forks etc. I'd be lost without mine.
  3. Hudson
    That was also an idea (and my 1st choice) but i have a 954 and can not find anybody who has one who can recommend it. I had heard of people buying the wrong ones and then it hitting the top fairings or not clearing the front mudguard etc..... so finding someone who has a 954 and uses a top yoke stand to recommend it is not easy, hence the idea of a standard front stand.
  4. billo01
    billo01 Member
    So which manufacturer of yoke stand would be recommended to suit an 09 C-ABS, one that could be used with an ABBA?
  5. GappySmeg
    GappySmeg Well-Known Member
    The local bike mechanic (Remal's mate Chris) used a bog-standard ABBA yoke stand on my 929... there aint much difference in dimension/layout between a 929 and a 954...... hope that helps.
  6. Midrange
    Midrange Active Member
    ABBA have just brought out an attachment to go with their main stand which means the front wheel can be lifted off the ground as well as the back without the clutter of a stand round the front wheel. Around 45 quid plus P&P
  7. Hudson
    I will have a mooch for that, i have their front lift but its bollocks compared to the Abba main stand. Cheers for the heads up.
