Best PCV Map
Discussion in 'Mods, Upgrades, Accessories and Products' started by t0m541, Mar 29, 2015.
  1. t0m541
    t0m541 Senior Member
    I fitted a PCV yesterday with the O2 eliminator.
    My bike is an '07 with flapper and pair valve mods, K&N filters, standard zorst but de-catted and baffle plates removed from rear silencer.
    I'm booking the bike in for a dyno/map session next week, however, I need a base map so I can ride it.
    I've looked through the Power Commander list of maps and the closest one I could see was this
    European model, 2006-2007 Honda CBR1000RR, Moriwaki full exhaust, Stock or aftermarket air filter, Airbox flapper valve removed, O2 eliminator installed (P/N: 76423008)
    Will this be close enough ?..
    I've looked at the Moriwaki zorst and it doesn't seem anything special and thats the only difference between that listing and my bike..
  2. ccr32
    ccr32 Active Member
    Sounds like a pretty close match to me, so I am sure it will work for you for now, and the dyno tuning will perfect it :)
    • Disagree Disagree x 1
  3. Greco
    Greco Active Member
    Hi T0m541
    After you installed the pc5 and the eliminator, have you noticed any benefits on your bike as i am looking on buying one. I have a 2007 blade too.
