Best place for HID ballasts on a 2010 blade
Discussion in 'Mods, Upgrades, Accessories and Products' started by Yorkshire Tyke, Feb 23, 2013.
  1. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    Its probably been asked before but can any of you kind people offer some advise on where to mount the ballasts for a HID kit?? A friend was nice enough to give me some FOC but they are canbus and there's quite a lot to hide.. This picture might help explain a bit better...
  2. JM1
    JM1 Active Member
    You can make some extra space by removing the intake flapper gubbins, or by fitting a small lithium battery
  3. phantomx0_1
    phantomx0_1 Active Member
    It's not easy on the 2008-2013 blade especially with that kit you have. I have my dipped beam HID. However my kit has only the ballast and bulb and not that extra inline box yours has. I have my ultra slim ballast nicely fitted behind the plastic under neath the right headlight. I had a kit like yours before the one i have now and The only easy way is to remove te whole side fairing and try to squeeze it neatly in there but is tight. I think some have it mounted in the air intakes if you have done te flapper mod. Also to do the bulb neatly you will need a spare rear bulb cover. I have drilled mine and then you can snugly fit the grommet to make it nice and air tight.
  4. Yorkshire Tyke
    Is there any guides to mounting in the air intake?
  5. Si.
    Hi mate, i have just ordered some, and i have ordered a 1m extension lead too, so i can hide the ballasts etc…
  6. Yorkshire Tyke
    Turns out the ballasts actually come with a bracket!! Anyone got any ideas if these will help and where to mount??
