Best way to remove akrapovic baffle
Discussion in 'General 1000RR Discussion' started by tgosai, Feb 23, 2014.
  1. tgosai
    tgosai Member
    What the quickest and easiest way to insert the securing bolt for the baffle on a shorty akrapovic without having to take it off each time
    I find it really tricky and fiddly to do it with the small gap between the can and the swing arm.
  2. Repsol Rob
    Repsol Rob Elite Member
    Often wondered about carefully drilling and re tapping on the outside and refitting bung............ as it a right pain in the arse !!!!!!!1
  3. Bloy182
    Bloy182 Active Member
    #3 Bloy182, Feb 23, 2014
  4. rodders4legs
    rodders4legs New Member
    How's about selling it to me :p the baffle I mean :)
  5. Repsol Rob
    Wont be drilling or re tapping now !! ;)
  6. Bloy182
    you can get a universal baffle on eBay for £10
  7. Repsol Rob
  8. Bloy182
    ok £10 was a bit ambitious,
    get a straight one tho, not angled, and measure your hole first :D
  9. rodders4legs
    Is that the correct one ? I'm new to all this sort of stuff lol worth a gamble at £16 I recon
  10. Repsol Rob
    they are slightly angled.......... just check diameter of opening....... loads on ebay
  11. Repsol Rob
  12. rodders4legs
    But from the image the securing bolt is at the bottom on the akra the bolt goes through the side :/ so many to choose from lol
  13. Bloy182
    Most important thing is the diameter. You can always trim the length baffle to fit. Even if you just had the ring that would still reduce the noise
