Bike not starting help
Discussion in 'Maintenance' started by gringo, Jul 6, 2016.
  1. gringo
    gringo Active Member
    Need little help 2 weeks ago while riding home bike cut out twice now won't start can't here the fuel pump kicking in checked fuse under seat checked fuses in fuse box all ok
    I'm not the best at fixing things so where do I go from here any good guys on here that know there stuff I don't mind paying this is my baby and don't want Tom dick or Harry turning up if you get my thinking I'm in Winsford Cheshire thank you my friends
  2. blake7
    blake7 Active Member
    Check kill switch to make sure no water in there. Side stand and clutch switch also for continuity.
    You can also put power direct to pump to ensure the pump is not at fault
  3. gringo
    Thank you I'll check them tonight
  4. danthorrr4
    danthorrr4 Active Member
    What year of bike?
    This happened to my 2004 Blade a few months back and it turned out to be my stator, it had burnt out meaning the battery wasn't getting any charge.
    This was a problem on the 2004-2005 bikes.
  5. gringo
    I have it on a optima the power seems ok it turns over fine just when I turn ignition on I don't it the fuel pump making a noise but all ideas welcome one will be right thanks
    Rr5 2005
  6. danthorrr4
    Alright OK, how many miles has the bike done? Mine went around the 16,000 miles mark.
  7. gringo
    12000 don't go our in the wet only time it got wet was a while ago when I washed it
  8. gringo
    Anyone in Cheshire that's knows how to test all the things that need testing ?
  9. johnd
    johnd Active Member
    Have you checked the kill switch? Mine failed 2 days after picking it up and was replaced by the shop.
  10. gringo
    Had a look at it no wet in it how do I check it
  11. johnd
    johnd Active Member
    I would open it up and check it for connectivity, if you can bridge the connections and see if the fuel pump primes.
  12. gringo
    Some things I can do change radiator plug brake pads discs oil filter etc but electrics testing I would more then likely blow something up I'm useless with electrics thanks for advice I need a mechanic or some one who knows there stuff I'd rather pay then ruin my bike if you know where I'm coming from really need to get it sorted going to be a good weekend next week so my Mrs says
  13. johnd
    johnd Active Member
    Pity you couldn't pick up another kill switch and try it. Mine actually turned out to be a break in the wiring and they are just a plug in job after you strip back the fairing to get to the connector. Gotta be worth a try.
  14. gringo
    I know got a mechanic coming Thursday evening so will put up problem when sorted if ano one else as a problem thanks
  15. blake7
    If you were closer I would of happily popped over pal to take a look. Hope you get it sorted in Thurs.
  16. gringo
    Thanks mate this guy will sort it can't wait thanks all for info
  17. gringo
    Well my mechanic didn't show had to go on a break down bugger
  18. gringo
    Don't worry I'm coming Saturday (great I'm thinking) finish work early lit fire in garage spoke to him he's going pick engine up from somewhere then I'm coming that's 11.30 2.30 I can't come got people in work shop can you bring it to me error no it's not running I said can you come Sunday or in week he says I'll call y.ou before I finish today don't think I'll hold my breath what's wrong with people, to say I'm gutted is a under statement
  19. blake7
    Nothing worse than being messed about pal, especially when you really want it sorted asap. Did he ring?
  20. gringo
    Did he fuck bloody arse hole that he is. got number for other guy tonight calling him tomorrow at least he returned my text right away
