Bit of throttle needed on start up
Discussion in 'General 1000RR Discussion' started by Glenandemm, Mar 9, 2021.
  1. Glenandemm
    Glenandemm Active Member
    When I took my 2015 blade out last week for a good few hours, everytime I stopped for a break then went to start it up 5-10 mins later it almost needed a little throttle to get it fired although it did fire without it but needed spinning over longer.
    I’ve fitted a pc5 and unplugged and blanked the o2 sensor, would this be why it needs a tad throttle to fire up quicker?
  2. edderby
    edderby Active Member
    Just a thought, but were you running on fresh fuel or a tank that was last filled before winter? On my blade, old fuel can sometimes make it hard to start without holding the throttle open. That's why I now fill up with Esso high octane before hibernation - it seems to decay less due to higher starting octane and no ethanol.
  3. Glenandemm
    hi pal it was my second tankful since winter hibernation so I think it would have been ok and I filled it up with the posher stuff too!!
    It will start without throttle but just a tad helps it fire up first turn over!
  4. Fatboy
    Fatboy Active Member
    How does it run without the PC on
  5. Blade runner 1
    Blade runner 1 Elite Member
    Maybe try resetting the ecu. As the o2 sensor is disconnected, there could be data in there conflicting with the current conditions.
    Disconnect battery for ten minutes
    Reconnect battery
    Start bike without throttle
    Wait for fan to kick in
    Hit the kill switch
    Turn the key off
  6. Glenandemm
    Cheers buddy, exactly what I was thinking of trying when I role it out next time it stops raining!!
