Blade 1000 RR CABS 2012 Engine knock
Discussion in 'General 1000RR Discussion' started by Tona955, Sep 5, 2022.
  1. Tona955
    Tona955 New Member
    Hi all,
    New to the forum and a blade that I recently bought with a engine knock.
    The knock seems to be louder on the clutch side and is a hard knock sound so I don't think it is the CCT.
    I removed the clutch cover today and removed the basket, first think i noted was the oil pump chain having some slack approx 8mm, pretty sure I read somewhere that it is normal but would like to confirm this please.
    As the cover was removed, I tried to check play in the con rod that I could reach , there is no left/rights movement but up and down there is a little , again not sure if this is expected.
    I wondered if anyone can suggest any other checks I can do from the clutch side?
    Many thanks in advance.
  2. Coda
    Coda Active Member
    I would have thought the conrod would have no movement at all as it will be fixed at the big end to the crank via bearings?
  3. Tona955
    Tona955 New Member
    Exactly my thought, I read that the 07 to 2010 had issues like this but have not found anyone with a 2012 with this issue, bike has only covered 17000KM, I had a feel of the right side cam chain and it does feel tight, which makes me think it isn't a CCT issue..piston slap perhaps.
