Blade racing parts updated
Discussion in 'Parts, Accessories & Clothing' started by foenix, Oct 5, 2015.
  1. foenix
    foenix Active Member
    Bargain on the last items :
    - Dyna 2000 ( ignition tuning ) => 90£
    - Akrapovic S bend road legal NEW + all the hardware => 120£
    or Dyna + Akro => 200£
    - 2013 Shock + white2013 hugger: 120£
    - 2012 Matt Grey fairings + headlight + air ducts + tech Spec tank grip installed + OEM 2012 screen + OEM 2014 SP screen => 450£
    - 2014 black rear subframe 100% straight => 120£
    - radiator black perfect = > 100£
    - fuel tank => 100£
    - L/R clip on => 70£
    - 2012 full OEM exhaust perfect => 150£ shipped
    2 left mirrors ( one perfect, the others just a little scratched), a cylinder bloc 10 000 miles in perfect condition.
    - Lot of fairings :
    - one 2012 tank cover red/white NEW never see a bike + red tank infill panels x2 => 140£
    - One 2012 black a little scratch => 80€
    - one right side 2012 fairing black scratched => 90
    - one left side 2012 red/white => 150
    - one 2012 black rear fairing + black under tray => 120£
    #1 foenix, Oct 5, 2015
  2. foenix
    brembo calipers update
  3. foenix
    Add wheels
  4. Moon
    Moon Active Member
    Do you have any pics of the wheels?
  5. foenix
    Pics are heavy, do you have a mail ?
  6. foenix
    here some pics, bloody mint conditions :)
    Front rotors will be OEM , these Brembo are sold.
  7. Moon
    Moon Active Member
    Do the disks have the holes for ABS sensor rings?
  8. foenix
    No, but you can make it.
  9. foenix
    Angle valve have just a tyre change.
    Du to some PM, i can split OEM front/rear for 150£ shipped and wheels naked 450
    #9 foenix, Oct 6, 2015
  10. foenix
    Wheels remove pending payment.
  11. exuptoy
    exuptoy Elite Member
    Cyrille, what size is the outlet on the Akra 'S' pipework?
  12. Repsol_Dan
    Repsol_Dan Active Member
    Does the s bend have the cat in it?
  13. foenix
    Hi Mate,
    exit diameter is 52mm.
    Yes S bend have cat, valve, never used.
  14. exuptoy
    Thinking of changing my Yoshi and Bazzaz for an akra with sports cat and flap (which I may just not connect)! Would the Yoshi can fit the akra link pipe?
  15. foenix
    If the yoshi is 52mm of course it will :)
  16. exuptoy
    Thats what I was getting at, to save me going up th garage and measuring it!! I know it will fit if it was 52mm I wanted to know if YOU knew? :D
  17. foenix
    lillllllllll sorry, i don't know, i had a full yoshi on my first track blade but i had never mesure it.
    Go to your garage, it takes only 5 minutes lol.
  18. foenix
    uPDATED
  19. foenix
    Updated with my bike parts :(
  20. foenix
    Open to serious offer, respond to everybody.
