bleeding brakes
Discussion in 'Maintenance' started by D16PJM, Jan 6, 2019.
  1. D16PJM
    D16PJM New Member
    I have fitted braided lines and have spent the evening bleeding the brakes, question is why are bike brakes so hard to bleed, bike is currently on stands with the lever cable tied to the bar.
    on a lighter note the wife was helping me and when i started bleeding the left caliper i said nothing is coming out only to see here pulling the clutch lever.
    Pete
    • Funny Funny x 3
  2. tuktuk
    tuktuk Elite Member
    Can be a bit of a pain sometimes. Rear caliper is a nightmare I find.
  3. nigelrb
    Seemed to take ages when I did mine on non-ABS 2011. Just a matter of patience;).
  4. Bikeboy
    Bikeboy Active Member
    The issue is the volume of fluid being moved when you pull the lever is very small.so any air in the system floats back up between releasing the lever. It's like 2 steps forward 1 step back. I use a mitivac. Pulls a large volume of fluid through at a time . Including any air bubbles trapped in the fluid.
  5. raphael
    raphael Elite Member
    crack the banjo that goes into the master cylinder as will release all the air going to the top, I find it makes a difference
    • Useful Useful x 2
  6. nigelrb
  7. Spygoat
    Spygoat Well-Known Member
    Mitivac is a necessity when you do your own brakes. Makes the rear so much easier.
