Bleeding ears...
Discussion in 'General 1000RR Discussion' started by fireblade_ro, Jun 14, 2014.
  1. fireblade_ro
    fireblade_ro New Member
    My bike is SO loud that after a long ride my ears feel like they're about to bleed - I'm actually quite happy with this.
    Sadly I don't think my neighbours are :(
    Do I get a baffle for my exhaust? :(
    Feel like I'm ripping the vocal chords from a happy puppy if I do :(
  2. Gilesy
    Gilesy Elite Member
    do you use ear plugs? couldn't ride without them :)
  3. Barstewardsquad
    +1 for ear protection.
  4. Matty1985
    Matty1985 Member
    what exhaust do you have? after changing mine ear plugs were the only way to go!
  5. madmac
    madmac Well-Known Member
    Ear plugs are a must! Gonna get me some custom ones moulded at the NEC show this year :)
  6. Ratser
    Ratser Well-Known Member
    Long rides I have to wear ear plugs with mine or I would be the same.
    Short runs are fine without. :D
  7. Matty1985
    Matty1985 Member
  8. thezipsteruk
    thezipsteruk Elite Member
    Not only that...earplugs are easier to install and to change your mind :)
  9. Stevie_d
    Stevie_d Senior Member
    Bout £60 while at bike show nec November, money well spent
  10. arthurbikemad
    Pop in I can sort you out ;)
    • Like Like x 15
  11. Barstewardsquad
    Think 200 pairs if Moldex Spark Plugs just cost me £18. Don't buy from bike shops though as they will gouge you, just get them from a safety goods shop.
    Used to have a set if ultimate ears but ears change shape over time and now they don't stop enough noise. If I want sat nag or sounds I use Comply Isolation Plus tips on my Shure headphones.
  12. Stevie_d
    Yeah your ears are the only body part that never stops growing all your life, it may happen slowly or a bit at a time. So there's no telling how long they will last. My work earplugs lasted 3yrs till they were ont borderline of not blocking enough noise out. Work ones are by ottraco got solid plastic type, like the ultimate ear hobbies fort bike. Very comfortable. Worth £60 IMO
  13. exfire
    exfire Elite Member
    My ears ring a bit after a long ride. I should wear ear plugs but they stop me from listening to the wonderful sound of the zorst and air intake. If I start to go deaf I will buy a louder exhaust ;) As for my neighbours, they make more noise than any exhaust so it's nice to give a little payback.
    Makes sense to wear them, bit late now though after 40 years.
  14. sps170373
    I put a baffle in on my exhaust if I'm going out early in the morning to not pee off the neighbours, also wear ear plugs
  15. fireblade_ro
    Thanks for the advice... I've no idea what exhaust it is I have except that it's an Akro! As for ear plugs... I tried the waxy ones but when I put my lid on the moved and ended up tangled in my hair. Waxy fail.
  16. marco s
    marco s Active Member
    Wouldn't leave home without them :)
    #16 marco s, Jun 15, 2014
  17. sps170373
    Foam ear plugs are good roll them between your fingers to compress them then put in and wait for them to expand
  18. madmac
    Yeah - them are the ones (there's another company that do them as well iirc). You book a slot at the show and they do the fitting there and then and then post them to your a couple of weeks later. A lot cheaper than getting a fitting yourself and then sending them the moulds...
  19. madmac
    How do you find them? Do they just block out the high frequencies so you can still hear conversation etc - or do they just block all noise?
  20. rewy..rr
    rewy..rr Active Member
    Agree with sps, foam ear plugs cheap and do the job about £6 off ebay for 25 pairs.
    You dont want to do permanent damage to your ears.
