i am new to a fireblade and it's a great bike but i have a problem with it. 2005 and it bogs down in first when you take off, after that it's fine. any ideas why it does that ?
Mine dose that, I put it down to the exhaust I got on, hopefully the power commander I just bought should sort that out.
Any changes to a bike and a dyno will help a lot. I have a Yoshi on my 11 blade and will be getting a Bazzaz and Dyno time in the spring
Does the bogging occur all the time or just when cold? If so then starter valves needs adjusting did a couple last year with the same problem both were out by a country mile.
Check the intake flapper is working smooth and at the right time, easy thing is google or search flapper mod and dissable or remove it. They do stick.
it does it all the time. i have a haynes manual so will look for the valve your on about. so if i block it off thats ok ?
Dose it have a power commander fitted? Dose it still have the yoshi pipe fitted? I think a power commander and a dyno run are the way forwards. Miune you only notice when pulling away in 1st gear. Its the only time my revs are that low.
still has the yoshi fitted. no idea if it has a pc, where would it be fitted. theres no room under the seat and the tail lol
it would be under the seat mate. My money is on the fueling as it has no power commander. The only cure is a power commander and custom set up on a dyno. Thats all about £500 all together if you buy new.
well i did that mod today in work, seems to be better but i only rode it 5 miles home in the wet bloody nightmare to work on tho, how the feck does the tank come off after undoing everything.
