Booked in
Discussion in 'Lounge' started by wedgiewolves#223, Jun 28, 2013.
  1. wedgiewolves#223
    wedgiewolves#223 God Like
    Just spoke to dynojet uk and I'm booked in for 2 maps for the blade baffle out and baffle in cant wait woooooo 15th July . Then acu test 20th track day 21st busy boy July !
  2. Remal
    hope your happy with the results mate
  3. wedgiewolves#223
    Hopefully they do a good job for me I ain't too bothered about bhp results its quicker than ill ever be just want it running at its best
  4. phantom
    phantom Active Member
    should make a real difference.
  5. wedgiewolves#223
    Hopefully she seems a little lumpy low down
  6. phantom
    mine is like that but only when I used the supplied baffle.
    felt like it was choking the bike
  7. wedgiewolves#223
    Yeah pretty much the same that's why I'm gonna get the 2 maps done . Might even get the map switch as I'm idle lol
  8. phantom
    I know that dyno guys should know already but remind them
    about blocking the pair valve pipe before they start.
  9. exfire
    exfire Elite Member
    Good idea Wedgie, mine is done like that and there is a noticeable difference between the two and it is nice to be able to switch between them.
  10. Remal
    just my thoughts also. hear people say under 170BHP is low? the blade only makes standard 175 at the crank so When I got 161BHp at the back wheel and it felt better I was very happy.
    And I mean if it's standard with not much work
  11. wedgiewolves#223
    Cheers buddy mine all gutted pair plates on there
  12. sinewave
    Tell me more about this 'pair valve pipe' ? :confused:
  13. wedgiewolves#223
    I'm not 100% so tell me if I'm wrong but it recirculated old exhaust gas has 2 openings on cam cover then pipes remove all this block them off frees up loads of space and easier to dyno
  14. phantom
    its a bit like Audi's egr valve, it injects fresh air into the exhaust to
    lower emissions so when put on a rolling road the dyno wont read the
    true air/fuel burn.blocking it also stops the exhaust popping on the over-run
    p.s.wedgie where did you buy the plates from, I can only find american suppliers.
  15. wedgiewolves#223
    Yeah buddy Kyle racing but anyone good with measurements mate could have some made these just glorified with Cbr logo that you never see
  16. phantom
    cheers..im leaving mine in for a few tweeks so I will get them
    fitted while the bike is stripped.
