BPF Forks oversprung
Discussion in 'Mods, Upgrades, Accessories and Products' started by Jez, Aug 8, 2023.
  1. Jez
    Jez Senior Member
    I have been thinking of getting my forks sprung to my weight for years but being from Yorkshire I am to tight, But my son bought a race bike with 9nm springs ( R6 ) and got me thinking of changing mine, so I have bought 9nm springs for mine and it has made so much difference, the standard springs are rated at 125kg + I am 72KG with no gear,
    I was worried that I would lose fast corner stability going for a lesser spring rate, but it is still on rails and just takes out the harshness,
    I am an average fastish rider on the road and still had 25mm travel left but used preload to get static sag down. (I am not hard on the brakes ), if you like your brakes maybe a 9.5 would be better at my weight
    The standard 2012-2019 BPF fork has a spring rate of 11.3nm which is ok if you want a passenger but if you are like me, an old git with no mates, I want it to be closer to my weight and with a bit more comfort over the bumpy roads
    It seems even the racers do not use anyway near 11.3nm springs supplied as standard. the SP is only 10ish
    Next is the rear shock, It has a 114nm spring as standard but for me wants to be about 100nm but it seems they take a bit of fitting as they are not made for changing
    I have put the K Tech chart below,
    #1 Jez, Aug 8, 2023
  2. LowSide76
    LowSide76 Active Member
    This is a good find. I'm about 98kg and just gone with feel etc. I've fitted a bitubo rear shock and had that set up for me and when my sons on back as well.
    The bike feels better with my son on back but is still awesome tbf with me solo. I've softened pre load up on front but dialled in damping a bit more than standard settings.
    This may be on my to do list now as I may be better with 10s or 10.5s. Something to think about for winter
  3. Jez
    Jez Senior Member
    What I should have also put is this is without rider gear
  4. Jez
    Jez Senior Member
    I am now wanting to change the rear spring but it seems they do not do these anymore for Showa 13/19 shocks, as far as I can see the spec for the rear spring is 59mm ID 165 mm long, I need 100nm rate, anyone got one ? I will have to continue looking
  5. LowSide76
    I think ktech shoukd do one igmf you contact them
  6. Jez
    Jez Senior Member
    Hi, I can not believe no one does replacement springs, it seems K tech might have done them at some time according to Brookes suspension but they do not now, the original spring is 59mm id 165mm long 114nm, I got in touch with Maxton and they said they would respring but using adapters, I asked what size spring they would use but they have not emailed back to say, I am guessing it would be 59mm x 152mm as they use this size, and probably with a 13mm spacer, but still waiting for the reply
    half of me says ok but short, the other half is looking at a k tech 57mm x 170 spring, this would need work to fit but is a closer length,
    I can go bigger on spring id above 59mm and make adapters but would like 165mm to 170mm long 100n rate any help would be most appreciated
    the shock is coming out tomorrow and I will try to see if it will take a 57 id spring as these are quite common, from a quick look the shock body is 50dia and when compressed this goes into the bottom spring retainer, so in theory 50mm body going into a 52mm id hole and 57mm od,
    I would have to machine the new spring holders at each end
    as mentioned if anyone knows where you can get a 59mm id x 165mm long spring 100N spring that would be great,
  7. Jez
    Jez Senior Member
    Hi, so a quick update,the shock came out today, I measured up and found the spring is 59mm ID bottom end and 53mm top end, this explains why no one makes replacements
    I have ordered an Ohlins 01092-34 spring which translates to 57 Id 170 long 100nm this will fit and may be better than original as 2mm narrower,
    The original spring at 59mm has been catching the swing arm as shown with the wear (would be better if in focus ), I am now fitting a 57mm so this may now clear.
    the 57mm spring will fit better at the bottom as bags of slack which may be why it is catching the swing arm, I will machine an adapter for the top.
    I was after going to Brookes suspension today for the spring but they told me it was not open due people on hols so hopefully it will arrive tues, I will post more info then IMG_2442.JPG IMG_2443.JPG
  8. gixxerjim
    gixxerjim Active Member
    I had my rear resprung when I had my front forks done - tyres4bikes did this for me- resprung to my weight and riding requirements (though it was a long time ago)
  9. Jez
    Jez Senior Member
    Hi, How did it handle after, I was told Ktech used to do them, I have the new Ohlins spring coming hopefully Tues, I have made a stainless steel adapter, just waiting for the spring, IMG_2451.JPG IMG_2450.JPG
    #9 Jez, Aug 13, 2023
  10. Selmer50mark
    Selmer50mark God Like
    Nice work Jez
  11. gixxerjim
    Was one of the first things done so can't comment before /after really. Always get it done to suit my weight.
  12. Jez
    Jez Senior Member
    I should have done this years ago, I have only done the front up to now but it has made so much difference, I have spent a lot of time adjusting the forks and shock over the years and it has been ok on some roads and not others, or the temp changes and it is not as good,
    but in reality you only have to look at the spring rates and if they are not right you do not get the suspension travel you need, it makes the compression and rebound adjustments very sensitive
    The new spring should come tomorrow, no Ohlins springs due til october so have changed to K Tech
  13. Jez
    Jez Senior Member
    So the new spring came today and was fitted, I checked sag and I had 10mm static and 36mm ride which is quite good, I took it out for a quick ride and the rough places I used to hold on I don't have to now it is so much smoother, I can still go high speed with full stability, I have not adjusted compression or rebound on front or back yet as waiting til I had finished, it should only improve
    The spring is 5mm longer than standard and the adapter is 1.8mm this gives 6.8mm preload before any adjustment.
    the shock has a 3 to 1 ratio so tomorrow I will take 1mm off the preload adjuster and will give me 13mm static, probably don't need to but would prefer 13mm static, this would give 39 mm rider,
