Braided hoses on ABS model
Discussion in 'Mods, Upgrades, Accessories and Products' started by stevebetts, Sep 21, 2011.
  1. stevebetts
    stevebetts Well-Known Member
    This could well be a silly question.......
    I always upgrade my brake lines to stainless braided.
    This is the first bike i have had with ABS fitted.
    Anything different or any issues with this upgrade on ABS models?
  2. scratcher
    scratcher Active Member
    Yep you have to get more pipe work for the abs side of the system. I did see someplace that full system bleeding is hard with the abs. I thinks HEL do the full system for ABS bikes
  3. abv
    abv Active Member
  4. stevebetts
    Hmmm.
    I will leave it for a while.
    If i am at a loose end over the winter months I may do it.
  5. dan.1moore1
    Wow that is expensive
  6. Givover
    This is the first bike that i will leave alone .i will just upgrade the pads if required.
  7. Bats
    Bats Active Member
    Got mine for 100 notes off ebay HEL guess the guy bought em and thought fook that haha!
    Easy to do just normal bleed ing a bit of thinking and modding jobs a gd un :)
  8. johncbr
    johncbr Active Member
    iv got a set of hel lines for the abs fireblade front and back new in black with gold ends !! im in no rush sellin them so there here if any one wants them ! front ones was fitted but only for a week took them off back ones not used ! got loads of abs stuff im not usein my bike was abs the brakes was good cant foult them but i just got bored with the abs so took the lot off :eek:
  9. Swiss T
    Swiss T Active Member
    I usually 'upgrade' my lines with HEL at some point.
    My current ABS brakes are just fine so I'm probably not going to bother with this bike, but I did wonder if it was worth doing ar all as an upgrade.
    I know they should be changed when the OEM age & are often changed for better looking items, but on the ABS bike, will the ECU allow a 'performace' upgrade. I understand all the braking goes through the ECU & its this which decides how much braking force you are going to get. I guess the braided lines will send a more accurate signal to the servo, but the ECU will still only give you what it thinks is required.
    So is there any point?
    Just wondered. :)
