brake buttons
Discussion in 'Maintenance' started by raphael, Jan 30, 2017.
  1. raphael
    raphael Elite Member
    anyone know how to release these as i was unable to keep on top of them over xmas due to an injury,
    i have used nearly a tin of brake cleaner and still cant get them turning
    cheers
  2. Muffking
    Stick something like an M12 nut & bolt through them and tighten them up until you can use one end to spin them round.
  3. raphael
    Cheers mate, I use a nut and bolt but by the sounds of it it's too small?
  4. Muffking
    Bigger washers? It only needs to grip both sides so you can use a ratchet/spanner to get them moving.
  5. raphael
    i have soaked them in brake cleaner and cleaned them, used bigger washer's and still can't get them to move! does this mean my disc's are ready for the bin? is there anything else i can do? i only left them for a few weeks when i dislocated my knee and they and seem to have seized solid.
  6. Slick
    Slick Elite Member
    Used M8s without problems.
    Have you have them spinning before? First time I did mine was after about four/five years of winters, got to be careful not to over tighten as it will just crush the button and seize the carrier to the disc.
    You just need to lightly nip the nut and only from one side rotate to free the button
  7. sulaco
    sulaco Active Member
    Here you go , watch from about 19 mins in.
  8. Great Guy
    Great Guy Well-Known Member
    Brilliant video. I will now go and look at my brakes.
  9. Great Guy
    Question. I get my bike serviced every year by Honda. But I have noticed that my front wheel does not spin freely when it is on the paddock stands. There is some friction caused by the break pads. Is this ok?
  10. Great Guy
    What is the brake button?
  11. sulaco
    Buttons, Bobbins they get called all sorts: (circled here) upload_2017-3-5_12-59-45.jpeg
  12. sps170373
    Try giving them a light tap with a spanner to shock them then try this again
  13. raphael
    Used to do them end of every month Jon and moved really easy but didn't do them for a month and now they won't move at all
  14. Great Guy
    Thanks.
  15. Great Guy
    IMG_1650.JPG Job done. All the "buttons" rotate.
  16. bradt
    bradt Elite Member
    Glad you asked the question Great Guy, I was also wondering what brake buttons were.
  17. Rids666
    Rids666 Active Member
    Cracking video. Love this guy :D
