Brake Light Switch
Discussion in 'General 1000RR Discussion' started by TheMickster, Apr 4, 2017.
  1. TheMickster
    TheMickster Active Member
    Hi All
    Just finishing the last few bits to put my trackbike back on the road.
    Does anyone know if you can use the standard brake light switches with a Brembo RCS master on the front and Gilles rearsets for the back? Or are brake banjo bolt pressure switches the way forward?
    Cheers
    Mike
  2. blake7
    blake7 Active Member
    Brembo do there own micro switch for the front brake and I'm guessing you will need a pressure switch for the rear
  3. icedmind
    icedmind Active Member
    my brembo RCS19 comes standard in the box with a optional light switch; rear brake just use a pressure banjo, can get them cheap on M&P direct.
    I got the RCS19 and SES rear set on my road legal 600 trackbike with the above setup
  4. TheMickster
