Brake pads
Discussion in 'Mods, Upgrades, Accessories and Products' started by Yorkshire Tyke, May 21, 2013.
  1. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    Best and cheapest place to get them and which ones?
    Also what's it like to change pads front and rear on the ABS models??
    Thankyouplease
    :D
  2. Slick
    Slick Elite Member
    Got some EBC hh off ebay.
    ABS is easy to change. Once the old pads are off just clean everything with proper brake cleaner and lube pistons with redgrease before pushing the piston back in. (You dont want to push dirt back into the calliper)
    Use that nylon wrap stuff that peeps used to bind boxes to clean the hard to reach areas of the pistons.
    Also coat the backs of the pads with silver grease to limit sticking pads and corrosion. The pad pins need a cost of silver grease too.
    if you havent got grease get these small tins off ebay, small but will last ages
    K12 Copper Graphite, Aluminium Graphite Compound & Red Rubber Grease 3 x 18 grms | eBay
  3. Yorkshire Tyke
    Thankyou sir!!! So its worth doing myself rather than paying labour?
  4. RichC
    RichC Active Member
    Yup EBC HH, decent fluid flush and you'll have great stopping power
  5. Yorkshire Tyke
    Is there a dummies guide to changing pads and brake fluid? Im an apprentice engineer so not maintenance shy just never done it. :)
  6. Slick
    Slick Elite Member
    TBH Honda dont charge that much on top of the price of pads IIRC 1 - 1.5 hr on top of the price of pads but it is an easy job.
    look in http://1000rr.co.uk/maintenance/119.htm for the manual
    but the dummies guide is
    Loosen pad pins
    Remove Calliper bolts
    Remove Calliper
    Remove pad pins
    Drop out pads
    At this point I like to scrub the discs with wet n dry
    Clean everything
    Red Grease pistons
    Push pistons in a bit
    Silver Grease back of pads ( with the metal shims in place)
    Install pads
    Silver grease pad pins and reinstall
    Reinstall calliper
    Medium loctite the calliper bolts
    Torque up calliper bolts then pins
    Do the other side
    Important
    Reprime callipers by pumping levers
    Test at walking pace
    Go for a slow ride and bed in new pads
    Edit:
    Probs a good idea to also clean the ABS speed sensors and do a conventional fluid bleed
    #6 Slick, May 21, 2013
  7. Yorkshire Tyke
    Whats the fluid change like? Do you need any special tools to bleed?
  8. Slick
    Slick Elite Member
    Bought a vacuum bleeder but IMO its PITA as it sucks air from around the nipple making it look like air is still in the fluid.
    Prefer just to do it ole Skool with a clear hose with a valve at one end and pump lever and loosen/tighten nipple etc. According to manual you should have the ignition on while bleeding but have the headlight fuse and stop horn/turning fuses removed
    I will be buying one of these though
    Speed bleed valves Auto brake bleed nipples Honda M8x3 | eBay - nipple size is TBC
    should make bleeding easier!
  9. thefirebloke
    thefirebloke Elite Member
    Spoke to my guy at Shorrocks and he tells me nothing but nothing comes close to SBS Dual Carbon pads. This fella really knows his stuff, he presented the trophy to the 1000 Superstock winner at Oulton Park recently on behalf of Pirelli. Apparently one guy tried them in the 675 Challenge Cup and now every single one in the series run them! And worst pads on the market were Brembo! Over-priced and over-rated, said he'd had nothing but complaints about them, just ask And7rp2, he went through a set in one trackday!
  10. sinewave
    SBS Dual Carbon are recommended for Track only, so one assumes they need some heat in them and the discs to perform at their best?
    Not ideal for a Road Bike then?
  11. thefirebloke
    Maybe you're right Sinewave, but then so are most dark visors and race cans, doesn't stop peeps using them on the road though. :)
  12. lexwon
    lexwon Active Member
    DC are for track use as you need heat'em up first, for road/track try sbs road/race sintered or stick with oem pads.
  13. sinewave
    There was a discussion on the Fireblade.org forum about how SBS DC don't perform very well in the wet.
    As above it's because they are designed for hard Track use and thus need a lot of heat in them to perform.
    Road biased pads will out perform any Track pad as high heat retention is next to impossible to keep on the road.
  14. stuart_g
    stuart_g Active Member
    I put SBS street excel pads in mine, much better feel and stopping power than the originals. Not a fan of EBC pads.
