brakes locking on
Discussion in 'Maintenance' started by paullec, Nov 25, 2016.
  1. paullec
    paullec Active Member
    Anyone had issues with the front locking on in this cold weather. Every time i go it the garage the front wheels locked on. Frees eventually is it the damp as i get a slight rusty patch where the pads locked on .
    its a 2014 non abs
  2. Dave dunlop
    Dave dunlop Elite Member
    Yep that will just be damp or wet conditions causing them to bind, just give them a clean with some brake cleaner and try and keep them free of moisture and you should be fine:D
  3. paullec
    weird only the 14 does it the rr6 is fine lol unless the pads have a high steel content hmmm
  4. Dave dunlop
    Yeh they will be sintered pads so quite likely to be the case, also if your old pads are a little glazed it won't cause such a an issue.
  5. paullec
    Just took them apart. All the pads had rust on surface. Must of been from when I washed it a few weeks back. Sanded them clean 're fitted.
