Brand new Blade , Should my battery sound this flat ?
Discussion in 'Maintenance' started by dan.1moore1, Apr 30, 2011.
  1. dan.1moore1
    Hi guys,
    Question to 08+ owners
    My Battery sounds flat when i start my bike. It always starts but sounds like it is struggling.
    The dealer warned me that it is just how the new blades are as they have a very small battery.
    Is this true with everyone elses bike? Is there a way to resolve this? More powerful battery maybe?
  2. JM1
    JM1 Active Member
    Yeah everyone is shocked when they first hear it.
    The battery is small but, in my experience, works fine as long as you keep it maintained with a tricke charger.
    Honda regreared the starter motor to work with that battery.
    You could buy one of those LifePo4 (or whatever it is) batteries if it bothers you.
  3. dan.1moore1
    Thats ok then. Thought i better check.. It doesnt really bother me as long as it starts ha
  4. Bikeracer1098
    Bikeracer1098 Active Member
    Try starting a Ducati 1098R with Pistol high compression race pistons and blue printed engine if you think the CBR1000RR struggles to start!!!! LOL !!!!
  5. Remal
    I use my Optimate a day or so before using my blade just in case. Went out yesterday and put it on change the Thurs. Going away tomorrow for the night so no need.
    but worth checking before going out
  6. stu-pendus
    stu-pendus Active Member
    Tractor always need bigger batteries M8.....................
  7. JM1
    JM1 Active Member
    OK I will do. When can I have a loan of it to try this out then? ;)
  8. DangerMouse
    DangerMouse Active Member
    If we're handing 1098R's about like they're Oyster cards I'll take it for a quick giggle around the North Circular :D
  9. Hondo
    Hondo Active Member
    There was one of these holding up the traffic on the A15 the other night. :Banane16::pleasantry:
  10. slowr1der
    slowr1der Active Member
    Got to say i thought the same when i started the blade earlier was almost like the 848 i test rode
  11. Bats
    Bats Active Member
    Thats good to hear just bought a 2011 model and thought hmmm cranking a bit sluggish so on goes the optimate and still the same bloddy technology ;)
  12. zeepony
    zeepony Active Member
    I've left it for a couple of weeks before and she always sparks up - if not, just bump it!
  13. dan.1moore1
    Iv had the blade for 2 months now and im used to it cranking slow now. as long as it works
  14. bladebhoy
    bladebhoy Active Member
    has anyone replaced their battery and if so with what, i am not impressed with the standard battery. has anyone had experience with lightweight batterys on calsport.
  15. BladeRR8
    BladeRR8 Active Member
    Would be interested to hear feedback on these myself.
    Regards the slow cranking just as others have said it did concern me a little at first but I knew Honda had fitted a smaller battery and altered the starter motor gearing accordingly so just accepted it and got used to it now and its always started every time, touch wood !!!!!!!!!!!! LOL.
  16. Speedytwin
    Speedytwin Active Member
    I did replace my battery in my 08 Blade but only because the cold winter killed it. But even them it starts so easy on a push I'd near let my 10 year old do it.
    I went for the standard battery again as said above with slow cranker and all that. But having an alarm on it and leaving it for a few weeks at a time while I ride the thumper (SP1) it needs a little push again but after a half hour of riding it's all good again.
  17. dan.1moore1
    Iv heard you can get a stronger battery but it doesn't improve cranking speed much. Mine starts first time every time so im happy as it is. Its a shock at first but Honda must have done it for a reason and you do get used to it
  18. Nutty Tart
    Nutty Tart Well-Known Member
    My riding bud always takes the weewee when I start up ... "one of these days etc" ... but after all "they all do that sir/madam"
