I am gutted to be doing this, but as my mate had a nasty off at Croft on Friday I have decided to give up track days. The bike was Keith Farmer's 2016 superstock bike, and has the following parts 2016 SP frame £1250 2016 SP engine £2500 Gold SP wheels and disc's £750 Akrapovic kit system £1000 Showa kit shock £750 SP Brembo monoblock calipers ,with brake lines £350 HRC front subframe with bottle holder and bottle's £100 HRC rear subframe £225 HRC rearsets £325 PCv with secondary fueling module and HM quick shifter £500 SP wheels with discs £750 Race spec standard loom £200 Radiator in excellent condition £200 Dash £300 Quick release fuel coupling and line £100 GB engine covers £100 ECU with ignition and key £300 PCv, secondary fueling module and HM quick shifter £550 Brand new 12-16 race fairings, Upper, lower, tank cover, hrc seat unit and airducts £350 Plus all the usual stuff Loads of sprockets Cheers Mark
Updated list 2016 SP frame £1250 2016 SP engine £2500 Akrapovic kit system £1000 HRC rear subframe £225 PCv with secondary fueling module and HM quick shifter £500 Race spec standard loom £200 Radiator in excellent condition £200 Quick release fuel coupling and line £100 ECU with ignition and key £300 PCv, secondary fueling module and HM quick shifter £550 Plus all the usual stuff Loads of sprockets Cheers Mark
