Breaking Honda CBR1000 RR-9 2009/59
Discussion in 'Parts, Accessories & Clothing' started by MrIII, Jun 6, 2017.
  1. MrIII
    MrIII Active Member
    Im breaking a Honda CBR1000 RR on a 59 plate 2009, has cover just under 16k miles its in Red and Black Most Parts available.
    Was broken down as i needed the engine for my kit car. Shame as was a lovely bike.
    Im based in Cuffley, Hertfordshire. So parts can be collected from here too.
    Parts already gone:
    Frame
    Engine
    Loom
    Clocks
    ECU
    Rear Pegs
    All nuts and bolts
    Both Mirrors
    Tank Cover
    Levers
    Handle Bars
    Top Fairing
    Screen
    Left Side Fairing
    Radiator
    Rear Subframe
    Battery Tray
    Headlight
    Rear light
    Fuel Pump assembly
    Let me know what you are after.
    Thanks
    Tony
    #1 MrIII, Jun 6, 2017
  2. jack
    jack Active Member
    Exhaust?
    Wysłane z mojego SM-N9100 przy użyciu Tapatalka
  3. MrIII
    MrIII Active Member
    Still available but has a little damage just to the left of the Yoshimura plate were the carbon and the metal meet, still works fine with no leaks.
    Thanks
    Tony
    #3 MrIII, Jun 6, 2017
  4. Scott
    Scott Active Member
    Surely u could have got a x Bsb engine or something
  5. MrIII
    MrIII Active Member
    Yes & No, Need the Engine, Gearbox, Loom, ECU & Clocks so was a cheaper option to buy a good running bike and sell of the rest of the parts, at least that way it wouldn't cost as much.
  6. Racer38
    Racer38 Active Member
    Hi Tony, How much for left and right handle bars including bar weights?
  7. MrIII
    MrIII Active Member
    Hi mate, sorry only just got a chance to get on here. Make me an offer! Did you only need the bars, grips and ends or was you after the controls too?
    Thanks
    Tony
  8. TheMickster
    TheMickster Active Member
    Hi
    I'm after a load of bolts, screws and trim clips etc to put my track bike back on the road.
    Have you still got most of them, if so I'll get a list together to send.
    Cheers
    Mike
  9. MrIII
    MrIII Active Member
    Have saved all the Nuts, Bolts and Clips.
    What did you need?
    Tony
  10. TheMickster
    Hi Tony
    Its mainly fairing bolts, clips and those black plastic trim fixings. Also the the screws to fix the headlights to the fairing, the front two tank mount rubbers, bolts and collars, i'm missing one of the hugger bolts and i've also got odd subframe mounting bolts, so maybe a couple of them too.
    I'll get a full list together either tonight or tomorrow and send you a PM
    Cheers
    Mike
  11. MrIII
    MrIII Active Member
    yeah have all those.
  12. vonryan
    vonryan New Member
    Any pics of exhaust please and a price?
  13. TheMickster
    Hi Tony
    I've sent you a PM
    Cheers
    Mike
  14. MrIII
    MrIII Active Member
    Received will see what i have from there and send you a pm. thanks
    Tony
  15. Hogkiller
    Hogkiller Active Member
    How much for the forks?
  16. MrIII
    MrIII Active Member
    No body want any parts?
  17. Blade954
    Blade954 New Member
    How much for left mirror?
  18. mish
    mish Active Member
    How much do you want for the complete subframe,seat unit.
  19. Lucky13
    Lucky13 Active Member
    Can't quite tell but is that a complete black tank cover ?
    Thanks
  20. MrIII
    MrIII Active Member
    Sorry mirror is sold already
    Yes it is a full black tank cover.
    Thanks
