Breather tube 2013 blade?
Discussion in 'Maintenance' started by paulbusdriver, Jun 8, 2013.
  1. paulbusdriver
    paulbusdriver Active Member
    Guys just wondered if anyone could tell me if there is a breather tube about 6 inches long that comes out of the bottom of the petrol tank and goes to nowhere. I have just fitted a new bmc air filter and when putting everything back noticed I had this 6 inch tube on the right side of the tank, next to other tubes coming out of the bottom, It has a bit of a hook shape to it. I suspect that it is a breather tube as I cannot see where it would fit.
    enjoy the weather
  2. sinewave
    Is it the overflow tube from the top of the tank?
    You have an Alloy fill level indicator at the top of the tank but if you overfill there is a tube connected to the space just above the fill level indicator which I believe directs fuel to the deck?
  3. wedgiewolves#223
    wedgiewolves#223 God Like
    White plastic bent tube sticking out tank is a breather this Is in 2 parts you could of lodt half of it ?
  4. paulbusdriver
    Just checked with a 2008 manual, yup its a breather pipe which should be fed through a hole which is at the edge of the fuel tank, so no worries then . Thanks for replies . Crescent Suzuki Verwood on Friday to put her on their dyno.PCV, BMC filter, Yoshimura R77 exhaust(not full system). only 900 miles on clock, but its had its 600 mile service!:cool:
