Brembo 19RCS with Hel Lines
Discussion in 'Mods, Upgrades, Accessories and Products' started by TW4T50N, Apr 21, 2017.
  1. TW4T50N
    TW4T50N Active Member
    Hello, I currently have a double line setup from the standard master cylinder but have an 19RCS to install.
    Does anyone know if the supplied banjo bolt with the 19RCS will fit the lines? If not, can someone provide a link to the correct double banjo bolt for fitting to the 19RCS and Hel lines.
    Cheers!
  2. tuktuk
    tuktuk Elite Member
  3. TW4T50N
  4. stupot
    stupot Active Member
    When I ordered my HEL lines from Mike at BDS he supplied me with the appropriate banjo bolt for the RCS
    Otherwise an extra crush washer would do tbd trick
  5. gcon45
    gcon45 Active Member
  6. TW4T50N
    Cheers for the recommendation, @gcon45, will look into it as I ain't interested in fudging anything on the bike.
    Garage it's getting taken to for installation may have something about. The new banjo bolt came with 3 crusher washers as standard from Hel.
  7. Jez
    Jez Senior Member
    Hi, It should not make a difference what master cyl you are putting the lines on, on a 2 line system you should have 3 washers and when you put the banjo bolt through the 2 lines and 3 washers there should be about 10mm of thread to bolt to the master cyl, more is ok as long as long as it will screw in by hand and not bottom out.
