Brembo master cylinders
Discussion in 'Parts, Accessories & Clothing' started by Racespares UK, Jul 15, 2015.
  1. Racespares UK
    Racespares UK Active Member
    We have just taken delivery of 20 Brembo 19 x 20 master cylinders and RCS master cylinders. These have been out of UK stock for ages.
    10% discount on these if you mention 1000rr forum or pm us. Further discounts available on all brake upgrade parts. Discs, Reservoir kits, Brake lines etc etc
    RacesparesUk
    01704 840825
  2. RepsolSam
    RepsolSam Well-Known Member
    Rough idea on costs? For a RR9
  3. Racespares UK
    We can do a 19 x 20 cast master cylinder with reservoir kit for £218 plus £4 delivery
    If you are using it on a road bike you will need a banjo pressure switch (single or double depending on your brake line setup) These are £10 if purchased with the master cylinder.
    Alternatively we can do an RCS Master cylinder with reservoir kit for £265 plus £4 delivery. This comes with a microswitch so no brake pressure switch is required if using it on a road bike.
