I know there is already a lot of threads relating to the Brembo RCS master cylinder but to throw up another question. I'm looking to upgrade to an RCS for my Blade SP. BREMBO recommend the 17 RCS as oppose to the 19RCS which I believe is the most common fitted by the forum members. Anyone done this upgrade on an SP, what RCS did you use and did you get any real benefit from the upgrade. Also planning HEL hoses. Thanks.
Yes I upgraded an SP with the 17RCS and braided lines. Should be a thread on here when I did it. I also had a little trouble doing the full bleed until i discovered the 2014 model bleed procedure is different. Brakes were amazing after the change. I Also insulated the module behind the headers from any potential heat effects..
