Fitted my RCS today but am a little stuck on the brake light switch connectors... the one brembo supply is bullet connector and the ones coming from the switch gear are blades... is it simply a case of cutting and crimping the brembo ones??
I should have added, are we allowed to call them spades, or should I be calling them flat sockets with curly edges
You’re fine mate, no liberal revisionists on here. If you want to sing baa baa black sheep go right ahead
