Brembo RCS
Discussion in 'Mods, Upgrades, Accessories and Products' started by Mr OCD, Apr 14, 2016.
  1. Mr OCD
    Mr OCD Well-Known Member
    Where is the cheapest place to buy these from now?
  2. 1premix
    1premix Active Member
    Capri moto Italy, paid about £220 notes, delivered to the door. Great service. Getting fitted tomorrow.
  3. Mr OCD
    £190 On eBay is cheapest found so far ...
  4. sinewave
  5. Mr OCD
    Just trying to get my head round what else I need ...
    - bracket ?
    - banjo (I'm running OE type setup - single line to dual)
    - reservoir
    - hose
  6. sinewave
    The Brembo RCS's tend to come with a Double Banjo, i.e. Race Line Set up with 2 individual lines direct to each caliper.
    Best bet is to order 2 Hel lines and specify 'Race Configuration'
  7. Mr OCD
    Typically the lines were only replaced six months ago with HEL... :/
  8. sinewave
    Double line direct from the RCS to each Caliper as seen below by the Green lines.
  9. sinewave
    In that case if they are split at a T joint or are of the 'Over the Mudguard' Caliper 2 Caliper setup then buying a single Banjo will be the cheaper option.
    Just make sure the Banjo U buy has a 'Brembo Thread' which is a narrower thread pitch then OEM at 1mm
  10. Mr OCD
    Titanium it is ... Lol
    Wonder if competitioner fasteners do it ...
    Cheers fella. Just need to sort bracket.
  11. Mr OCD
    Banjo is £7 ... cheaper than £50 for hoses again!
  12. stevet
    stevet Active Member
    so if for a road bike, what do you do for a brake switch
  13. sps170373
    Racebolt will do it
  14. sps170373
    RCS comes with a micro switch all you need to do is get some 6mm spade fittings and file them down to about 5mm and plug into the existing Honda connectors
  15. stevet
    Oh right...thanks
  16. Slick
    Slick Elite Member
  17. Mr OCD
    Sorted ...
    £176
    :D
  18. RepsolPaul
    RepsolPaul Well-Known Member
    Where did you get it in the end?
    And what did you do the about resovior ?
  19. Mr OCD
  20. Noste500
    Noste500 Active Member
    That's s great price !!
