Brembo Serie Oro front discs
Discussion in 'General 1000RR Discussion' started by morpheus20170, Apr 24, 2014.
  1. morpheus20170
    morpheus20170 Active Member
    I bought some Brembo Serie Oro front discs at the NEC Motorcycle Show and I had them fitted with OEM pads.
    I've got a strange feeling from the front.
    I've read in the manual that when replacing the front wheel the clearance should be measured between the disc and the caliper before tightening the left fork pinch bolts and I'm wondering if this may be the cause of my front end issue?
    Do you check the clearance whenever you remove/replace your front wheel?
    Please help me.
  2. Scott
    Scott Active Member
    Nope never. Should be able to look and see if centred in calipers etc. get a torch to see properly
  3. iang27
    iang27 Active Member
    Mine done that, the spindle was not fully in, only a couple mm but enough !
