Just replaced my bulbs and a quick question guys....is the dipped light more shielded than the high beam bulb....not noticed it till now...either it is more shielded or I have bulb in incorrect position. The two bulb positions just look different ????
Without going and looking I can't be certain, but I think you'll find it's just the shape of the reflector. It is the reflector that dictates low/high beam not the bulbs. Hence differ shape reflectors. I hope this helps.
yeah I get that....I realise the bulbs are in correct position but the dipped side appears that the deflector covers the bulb more.
Yeah that's right,usually find that on the dipped side. Just check bulbs are seated correctly and everything will be fine. If I remember right the bulbs do sit differently in each side,90 degrees out.
