I'm sure someone had posted what the c-abs bleed nipple sizes for the front & rear power and valve units was but I can't find the post even after using the search function on here and google. Does anyone know the sizes of them as I want to replace them with speed bleeders to make future bleeding easier. I already have the sizes for the brake calipers.
I remember looking at this a while back. The part number is PFKL595722 which is the same as the VFR750FL caliper which I believe is a 8Mx1.25 mm. I never fitted so it is a guess.
And is the same sizes as the rear brake bleed nipple and the front brake master cylinder for 08 onwards. Thanks for the info
