C-ABS HOW TO CHANCE BRAKE FLUID! HELP!
Discussion in 'Maintenance' started by klamothp, Apr 17, 2022.
  1. klamothp
    klamothp New Member
    HI
    like in title
    i need help with someone who know how to change the brake fluid in cbr1000rr 12-16 with c-abs
  2. Coda
    Coda Active Member
    I believe the procedure is documented in the service manual. Do you have it?
  3. Jez
    Jez Senior Member
    Why are you after changing your fluid, air in the system, service or changing bits, I have changed all my lines, serviced the callipers all just by careful bleeding
