Got my 2014 sp in Feb this year after changing from an 07 model which I have had from new. Really impressed so far, however on the way back from BSB at Donnington on Friday I had to filter for literally miles through standing traffic, during this I noticed the ABS light flashing continuously, after I had sopped for fuel at the services the light stopped. There is a section in the owners manual which stated that the light will flash if braking continuously from 0mph-31mph which woukd fit with the filtering? Anybody else had this?
Hi and welcome to the forum you may want to work your way through this https://www.1000rr.co.uk/threads/im...d-if-you-own-an-abs-2009-onwards-model.11881/
Hi, You would never normally brake from 0 to 30 as you would be braking and accelerating at the same time, unless you were going down a very steep hill
