Cadwell Sat 23rd July
Discussion in 'Trackdays' started by Edy, Jul 14, 2022.
  1. Edy
    Edy Member
    Off to Cadwell a week Saturday. 105 db static. I have a Leo Vince stubby on at the min. It is quite loud. Any feedback from anyone that’s done Cadwell with a similar exhaust would be appreciated.
  2. Trackit
    Trackit Active Member
    I suppose its a bit late now, if it has a CAT before the Leo can then you might make it, if it's straight through then you'll be struggling. I have a sound meter I use before trackdays.
  3. Edy
    Edy Member
    It does have a cat before. I have ordered a dB tester. I thought it was worth a shout on the forum just in case someone had the same slip on. If the bike fails the dB test, I will swap the exhaust for the stock one, again!!! Thanks for your help.
