1. Tommy rascal
    Tommy rascal New Member
    hi all could anyone tell me if 2008 on calipers would be an upgrade for my 2006 I've heard they are mono block.i have braided lines and accossato master already just thinking is it worth it
  2. derchef
    derchef Well-Known Member
  3. Mr OCD
    Mr OCD Well-Known Member
    I've had both and there is no difference at all between the R1/R6 radial units and the TOKICO mono's from 08> blade.
  4. derchef
    may sumitomo come with 30/27 mm pistons and tokico 32/30 ? :D
    what about braking surface ?
    may U talking about feeling
    Cause there are few differences
  5. scooby
    scooby Elite Member
    just because they are monobloc doesn't meanthey are better,look at hpk'S -V- m4'S for example,or the gprx's
  6. Tommy rascal
    They must be better otherwise they would have kept on using the 2007 calipers
  7. derchef
    they are sure a bit better , but for normal street use U will not find out that
  8. scooby
    scooby Elite Member
    they probablly are,but not because they are monoblocs as such,which you seem to think they are.i was just pointing out that just because they are mono's,doesnt make them better.
    piston sizes,materials used in the body,manufacturer process,pistons,seals etc are what make them better
  9. derchef
    and ALL honda bikes with 4 pot radial calipers (not sp or africa twin) have same pistons and same seals btw
