cam slight worn out
Discussion in 'General 1000RR Discussion' started by tazmania_1981, Sep 30, 2014.
  1. tazmania_1981
    tazmania_1981 Active Member
    hi guys just did the valve clearance and change of cct
    and mechanic showed me slight wear on my cam only two of the egg shaped thigns pushes down the valves has slight wear on them
    mechanic claims it is down to not good oil being used engine not heated up etc.
    i was wondering what your thoughts are ??????
    3 of the cyclinder clereance was ok apart from one i had little bit of clicking noise hope this will be sorted
  2. tazmania_1981
    cct changed but the bike is little louder on the right handside now than before everything is original part
    question is will it be adjusted after rirding it for a while ???
    after changing sparkplugs
    valve clereance and cct bike is starting and running alot smooter
    next month comes the oil and filter change
    camshaft we just left it as it was and i can hear slight thickin noise but i believe they are all like that
  3. wedgiewolves#223
    wedgiewolves#223 God Like
    My RR6 was noisy mainly clutch pull in went away loose it was there everyone told me stop listening to noises and ride it so i did loads track days loads euro miles nmever a problem then Honda brought it off me . So use it forget about the noise buddy enjoy
  4. tazmania_1981
    i think i will just get on with it
