Just wondering what people use and where mounted to the bike? I've got a little mini video camera with the standard 1/4" screw mount hole you get on most cameras and looking around for places I could mount it to the bike, and where. I've got a suction cup mount which I could mount to the tank, but not sure I really trust it to hold at 1+ leptons at Silverstone... Plus doesn't a tank mounted camera get in the way? Either that or I fashion a bracket out of something and find somewhere to put it on the bike...
Can u upload a photo of your camera? I don't use mine any more but might have the mounts, if they any good to ya you can have them
Here's my camera, and the mount hole. Unfortunately it's a bit of an awkward shape to mount in an air intake or something like that - would think I'd need to mount it behind the screen or something.
I'm looking at a 1" ball mount system that fits into the headstock tube. It's primarily for my phone to use as sat nav but they do GoPro and threaded mounts too. http://www.ultimate-mobiles.co.uk/C...roof_Tough_Mount_Case_for_iPhone_6_47?bid=108
Thanks Si, will give them a shout. Thanks also RRoss - I contacted them after seeing this (very similar to the Telferizer): http://www.ultimate-mobiles.co.uk/Attachments/Fork_Stem_Yoke_Attachment However it seems that they don't then do anything that would mount on to the ball and fit my camera.
Bob at Telferizer will make what you want if you can give him the spec... He did a custom ball mount for me to mount a camera on a mirror bolt.
Check out ram mounts for 1" ball threaded mount,seen one on Amazon for £10. I looked at the telferizer but found it expensive compared to buying the whole kit from ultimate mobiles.
Bob is on the case...! Just trying to sort out something that will work with my particular camera, but looking good so far... Thanks for the recommendations people.
Just to update, Telferizer mounts have been delivered, and Bob has also been kind enough to supply a couple of different varieties for me to try to make sure I get the right one for my setup, simply asking me to return the ones I do not need. Top bloke. Will post pics up once on the bike - fingers crossed all works as hoped.
I used my Telferizer mount with the 1inch ball today with my Ram mount fittings. Superb kit. You can just see it fitted here.
