Hi guys! Having fitted some pro-fibre carbon frame protectors last year, Im now considering removing them and replacing with R&G heel protectors. Question is, has anyone had experience with removing these? I used black silicon to install, just worries what kind of mess I'm going to find when I remove them What's best to use to remove the silicon from the frame? Cheers Hedges
Wd40 works a treat and wont harm the finish, remove a much silicone as poss, soak with WD40 wait a while and it should come off pretty easy(use a plastic scraper). There are specific silicone removers available, not sure of chemical contents though.
