I purchased a used carbon hugger really cheap from Flea-Bay as a temp till i can find a King carbon hugger to match my front. Any way , Im missing a bracket or something or is it that it is for an ABS ? If its a bracket could someone please take a pic so i can fabricate 1 ? wordpress image upload
would the stadard hose clip bot fit in them 2 holes if you turned it 90 degrees? looks pretty good by the way!
Possibly, Ill give it a try later.. Yeah its in good condition but the carbon doesnt match king carbon fender
I did away with the hose clips when I changed to braided hoses I think. Looking at that photo I'm pretty sure that the standard clip would fit those holes if you turn it round a bit. I would put some rubber or black electrical tape on if first tho to stop it rubbing against the carbon
Ill give it a go and report back. Seems strange that the guy would not have sent a bracket if it was a specific one for it. Hopfully you are ment to use the standard clip. Its gotta be better than a cable tie anyway lol
