catalytic converter
Discussion in 'Maintenance' started by mekanix, Feb 25, 2013.
  1. mekanix
    mekanix Active Member
    don't suppose anyone knows if the rr4 will have a cat?
  2. kev.b
    kev.b Well-Known Member
    Underseat exhaust RR4 have cats .
  3. megawatt
    megawatt Well-Known Member
    Most do. It's in that small 6 x 4 box on the vertical section of the link pipe. It can be removed, but it ain't easy. I have one that's already been removed ?
  4. mekanix
    Could do with getting that removed then and release the power that's being wiped out by it. When you say it's not easy, how hard exactly. Bare in mind I'm a mechanic so will be doing it myself. Wanna get her power commanded before too long.
  5. phantom
    phantom Active Member
    big screwdriver and persuasion tool
  6. megawatt
    Yeah, you gotta smash it out, but the metal matrix is a bit harder than ones I,ve done before.I used a long, big drill bit and a long chisel.
  7. Swiss T
    Swiss T Active Member
    I did read, but dont know if its true, that removing cats has no effect on power. The theory being that the internal area of the cat is the same as the internal area of the open pipe; this is why the part of the system which houses the cat is fatter (to compensate).
    I read this on the tinterweb so it must be true. :)
  8. phantom
    If that was the case why do aftermarket pipe builder's
    Do away with it?
    I do know one thing and thats that they store some
    Amount of heat.when I used to come back from
    A run on my duke you could see them glowing red.
    When I removed them the increase in exhaust noise
    Was shocking
  9. megawatt
    Well I've done two and both owners reported better throttle response and more power once fuelling adjusted. Even better with a hi flo air filter!
    I have one here if anybody wants to try one already done?
    #9 megawatt, Feb 26, 2013
  10. mekanix
    some helpful advice there guys, but i had a look at my exhaust and nothing obvious sticks out to make me think it has a cat
  11. megawatt
    Got any pix?
  12. mekanix
    i'll take a pic tomorrow and post it up
  13. JM1
    JM1 Active Member
    I have a feeling cat was introduced in 06, but could be wrong.
