cbr 1000 rr 2016 ABS Brembo Upgrade
Discussion in 'Mods, Upgrades, Accessories and Products' started by secabox, Oct 2, 2021.
  1. secabox
    secabox New Member
    I have a 2016 cbr 1000rr Repsol ABS model ,and i will upgrade my tockico calipers with the Brembo calipers
    from the SP model.Its this possible ?And what Brembo type calipers?
    I ask because its a ABS Model.
    #1 secabox, Oct 2, 2021
  2. Slick
    Slick Elite Member
    Should be a straight swap over, ideally you will need a full ABS bleed afterwards though I have swapped over calipers w/o the need of a full bleed.
  3. Jez
    Jez Senior Member
    I remove and service the calipers w/o full bleed, I have a 10mm bolt with a seal each side I put this through the banjo after taking off the caliper, just make sure the reservoir does not run out, keep it full
