Cbr 1000 rr helo
Discussion in 'General 1000RR Discussion' started by Morgan, Apr 10, 2024.
  1. Morgan
    Morgan New Member
    Hello guys im doing alot of modding to a 2008 cbr 1000 RR I have zero knowledge but I have a high high budget for my modding. The thing I need you guys to find for me is a quickshift ( complete with all you need ) that can quickshift up and down to start with
  2. Trackit
    Trackit Active Member
    You won't get a quickshifter that does downward shift blips on your model, only upward shifts. I recommend a "Translogic"
    • Agree Agree x 2
  3. Morgan
    Morgan New Member
    Thank you m8. Is this kit easy to install and with evertything you need in the kit? Also what dynojet ecu flash is the easiet and best?
  4. raphael
    raphael Elite Member
    Translogic is the best quickshifter and comes complete with all you need to fit.
    As for the ecu flash, it’s best to get a custom map as that will to your bike,from a good business it will be around 4 hours work and roughly 400-500 quid.
  5. Morgan
    Morgan New Member
    Would I need like dynojet for that?
  6. raphael
    No
  7. Singh1000RR
    Singh1000RR Active Member
    Are you planning track days? If so then i'd also recommend a Nova 3rd and 4th gear upgrade for your box if your fitting a QS.
    As others have said - cant do down shifts.....unless you swap for a 2017 model.
