cbr 1000 rr45/67 aftermarket headers
Discussion in 'General 1000RR Discussion' started by daz1, Dec 16, 2013.
  1. daz1
    daz1 Active Member
    hi all is there any diff between the 2004/5 and the 2006/7 after aftermarket headers because i was loooking at hindle headers for a 2006/7 and they say they dont fit the 2004 hindle as another part no for the 2004/5
  2. martinowen
    I'm pretty sure 6/7 fit the 4/5 but the 4/5 won't fit the 6/7 due to the 6/7 fairing bing smaller the pipes will catch the plastics
  3. daz1
    daz1 Active Member
    thanks martin
    arthurbikemad said prettymuch the samething in a pm thanks again for your help
  4. martinowen
    No probs mate
  5. daz1
    daz1 Active Member
  6. martinowen
    They look good :D
  7. lambchops
    lambchops Elite Member
    Oh very nice!! just what I need..
  8. daz1
    daz1 Active Member
    hi all i sent hindle and asked them what the diff was and they sent this email back
    Thank you for taking the time to contact Hindle Exhaust Systems.
    The two systems are very similar; however, the mounting bracket on the mid-pipe is in a complete different location. This mounting bracket attaches to the stock location - the 2006 model had a different stock location than the 2004 model.
    I hope this information helps answer your questions. Please feel free to contact us at any time should you have any other questions about our products. We are here to help.
    Kind regards,
    Alison
    so with a little modding it would fit i think
  9. martinowen
    What mounting bracket are they on about?
  10. daz1
    daz1 Active Member
    2004.jpg i think they mean the mounting hole on the stock headers as a mounting hole on the on the bottom of exhaust mid section that bolts to the engine or frame some were if you look at a set of stock headers you will see a mounting brk [ a plate ] welded the the back of the mid section with a hole in it for a bolt $T2eC16V,!wsFJQkqJPK6BSb6ZiD87w~~60_35.jpg you cant see it on this photo [ hindle system ] unless they are on about what i call the link pipe
    #10 daz1, Dec 18, 2013
  11. daz1
    daz1 Active Member
    there dosnt seem to be one looking at other images of the hindle system so now im not sure what mounting brk they are on about unless they are on about what i call the link pipe
    #11 daz1, Dec 18, 2013
  12. martinowen
    Yea the one on the link pipe I reckon, but where does that join too? I don't recall having one on stock pipe or any aftermarket I have fitted
    :confused:
  13. daz1
    daz1 Active Member
    $(KGrHqN,!nsE9fbJ3)VSBPmC65jYNw~~60_12.jpg on the stock end can the pipe that joins the standard link pipe as a metal tab welded to it with a hole in it that a bolt goes in to attach it to the subframe
    #13 daz1, Dec 18, 2013
  14. masterblader
    masterblader Active Member
    Visually there seems to be little or no difference, the welded bracket and location points are virtually identical. Assume the pipes themselves differ to clear the fairing as these are different. Keep us posted daz1 as I maybe interested too.
  15. daz1
    daz1 Active Member
    hi mate i resent hindle a email asking that if i remounted the mounting brk would they fit then just need to know what mounting brk they are on about as i cant see any on the system just waiting for an email back
  16. masterblader
    Thanks buddy. Pipes don't seem to have the bracing bracket between the pipes to locate onto the frame.
  17. daz1
    daz1 Active Member
  18. martinowen
    ok you most prob don't need it on the new one, I'm on my 3rd aftermarket exhaust and none have that bracket on the link pipe
  19. daz1
    daz1 Active Member
    another email i had from hindle Hello,
    The biggest issue is that the bracket is welded on to the mid-pipe. I would most likely have to be cut off and then re-welded at the correct location.
    I hope this helps - please let me know if you have any other questions.
    Kind regards,
    Alison
    so its deff doable and quite easy but i still dont know wich bracket they are on about there must be a bracket mount on the mid section some were ive re emailed them to see if they would send me a picture of it
    #19 daz1, Dec 20, 2013
  20. martinowen
    It's the one in the top of your pic mate I'm sure of it
