CBR1000RA 09 ABS info
Discussion in 'General 1000RR Discussion' started by Van Gijsel Stein, Jul 13, 2018.
  1. Van Gijsel Stein
    Van Gijsel Stein New Member
    Hello guys,
    I'm new to the forum.
    I would like some information about the ABS flickering.
    When i brake @ lower speeds my ABS starts to flicker and would not go off. (only if turn off and on)
    Someone i know told me to test my bike without the MAIN ABS plug plugged in.
    After some rides i notice my bike brakes much better as before.
    Is unplugging the MAIN ABS plug bad for my bike?
    Thanks for your time!
    Svg
  2. bradt
    bradt Elite Member
    Hi can't help you with the ABS issue but I'm sure someone will respond before the end of the weekend, have you checked other ABS related posts on here ?
  3. Van Gijsel Stein
    Hi :)
    yes, but no answer for my question :)
    Thanks for the respons!
  4. Slick
    Slick Elite Member
    unplugging the abs fuse just means the brakes are conventionally applied. will do no harm to the bike but it will not fix your original problem
  5. Van Gijsel Stein
    Thanks for you answer!
    I think i will leave it this way... much better respons :)
