CBR1000RR 06 - No clutch?
Discussion in 'Maintenance' started by FB2006, Mar 25, 2025.
  1. FB2006
    FB2006 New Member
    My CBR1000RR 06 has been in my garage since November. It's been sitting on front & rear paddock stands, with side stand down. I've started it a few times between Nov & March with no issues. Last time I started it the rear wheel started rotating but eventually stopped when I pulled the clutch in a few times. However, I did notice what appeared to be a lack of resistance in the clutch lever. Anyway, went to take the bike out today and clutch lever comes back to the bar and clutch doesn't seem to engage, bike lurchs and cuts out. After a few goes, had some vague feeling in the clutch and it would engage but not enough to ride with.
    Any ideas?
  2. CharlieR85
    CharlieR85 Elite Member
    Try bleeding it.
  3. Lock
    Lock Active Member
    Either slave or master cylinder - have you still got fluid in the reservoir? Just did slave on mine, replaced with an Oberon one, seems good
  4. FB2006
    FB2006 New Member
    Reservoir is full, am going to try bleeding it in the next day or so, to see if that does the trick.
    Thanks for the advice though, will bear in mind if bleeding doesn't work.
  5. Broadie
    Broadie Active Member
    It’s worth removing the slave and flushing out the old fluid.
  6. Muffking
    Bleed the slave cylinder down by the clutch cover. You only need to release a small amount of fluid. I had to do mine once per year.
