cbr1000rr 06 parts needed for full rebuild
Discussion in 'Parts, Accessories & Clothing' started by JayMB, Dec 11, 2022.
  1. JayMB
    JayMB New Member
    Picked up a written off 06 blade for free. Looking for donor parts if anyone has spares or am willing to pay!!
    Crankcase bottom end
    Sump case
    Swing arm
    Rear wheel
    Full exhaust system
    RH peg/rear set
    Subframe
    probably loads more
    any help would be massively appreciated
  2. Iain
    Iain Active Member
    I have a rear wheel and the rear part of the exhaust.
    Also front wheel, forks abd rear shock if that helps?
    Where are you?
  3. JayMB
    JayMB New Member
    Surprisingly the forks n monoshock are still good!!
    100% need that rear wheel/exhaust... the front has a slightly warped lip but still holds the tyre bead so hoping it can just be repaired.
    Im in Hampshire
  4. Iain
    Iain Active Member
    As it happens, I am in Dorset, Poole, so potentially not too far away if you wanted to see/
  5. JayMB
    JayMB New Member
    Do u have some pictures ??
  6. Iain
    Iain Active Member
    At this time of night, alas no! But it is about time I do something, so will see if I can break the ice tomorrow and get some taken.
