Power Commander 5 Working perfectly and guaranteed good Power Commander 5 for the 08 - 11 Blades. It wont fit the later blades as the fuel injection sub loom was revised for the 2012 bike. I have loads of good maps available. Just ask. £175 ONO Ignition Module. You MUST have a PCV already fitted and this will work with 2008 - 2016 model Blades. You need this or similar to use a dynojet quickshifter with the PCV due to the dual injectors. The beauty of the ignition module is you can have a launch control. You can also have a pit lane limiter. £150 ONO Quickshifter. The Blade normally uses a Push shifter. If you want one and the link rod I can supply with the above for £120. I can supply a pull if you prefer The £175 refers to the PCV. The other parts are separately priced. Barry 07921 849 076
Your not getting the friendly point.... You listed the item.. but there is NO PRICE on your ad... please add a price and info etc for people who wish to buy.
Ok cool.. push and pull isn't it that one? I have you on my facebook dont i... barry g?? If not will PM you on here
